- Member ID
- #797
- Messages
- 9,454
- Reactions
- 56,014
- Likes
- 402
- City
- SW Twin Cities
- State
- MN
- Country
- United States
- Vehicle
- 2019 Dodge Challenger Redeye WB
Okay, I am the guinea pig. Easy enough to get to it. NOT. Hardly one of the directions has been correct.
Remove two push pull pins for the side carpet? NOT, first took the carpet and simply ripped it out from the two pins, because they won’t budge. Then took the channel locks and ripped the damn pins out from the steel holes. Keep the one pin that did not go flying, because you will need it to buy two new units to use when the carpet is put back.
It is cool Dodge, put four holes (two on each side) of your controller, but only use three bolts and drilled three holes in the car. Yep, you guys guessed, my mood could be better this morning.
Anyway, here I am holding this thing. Easy as plug and play, huh? Well what I know is this.
Instruction...
Now here is what I am holding.
This old guy may not be that smart, but I have turned a wrench or two, and I have seen a weird thing or two built in my time. But if I use my gorilla grip, or perhaps help my grip with one or two of my favorite toys and follow that simple instruction to slide those connectors OUT WITHOUT RELEASING SOMETHING SOMEWHERE something bad is going to happen.
Because, there are these interesting rather serious looking retaining something or other thing that may just bust big time if I go attempting to translate either one of these connectors OUTWARD, TO THE LEFT AND RIGHT.
CAN SOMEONE PLEASE EXPLAIN TO ME HOW TO REMOVE (WTF TO PRESS AND RELEASE) before I bust something? I am going to go out and do something relaxing like mess with six inches of the white stuff. Hope when I come back someone can enlighten me. Then I will give the appropriate feedback where it is due, so everyone else who does this after me can make the plug and play happen in five minutes as promised
Instruction...
