Flat front tire at the finish line.
hell on wheels
Saint Paul
Dodge SRT Demon
Check your valve stem nuts
For tightness.
When you torque your lug
Nuts.
I lost all the air just after I crossed the 1320 stripe at 131 mph
From a valve stem loosening up.
Glad your ok , that could of got harry , I found a big sheet metal screw in one my DR's right b4 I was about to make a pass , don't know how that would have gone if I didn't see it ? ….so check your tires too once & a while for anything in them.
For tightness.
Nuts.
I had stems that were not torqued correctly.
They didn't come lose, but would deflect when at speeds above 120ish (which took forever to diagnose and confirm).
So I had a similar experience, crossing the one mile mark at 175 and only 20psi.
H
hell on wheels
Saint Paul
Dodge SRT Demon
I have removed the TPMS
From my front runners.
I ordered and installed a set of the valve stems from the crate.
I assume at times I was riding on the Tpms inside the tire
As they were inverted to fit the skinny wheels.
When I lower the front tire psi down to 30 psi
To time my roll out with the lights.
Which likely loosened the stem nut over time.
