I think she is done.:(
Thread Starter #101
And who the heck knows if it is the starter. He has not called me that the car is ready. With my luck it is something else.
Thread Starter #102
Starts and runs. They are keeping it overnight.
Make sure the oil got changed after the fix. The oil has to be contaminated with a shit load of fuel.
Thread Starter #104
Yes it was changed even before they put in the 1700s. And I will get that changed in 1000 miles.
Thread Starter #105
Car is running great now. Tuner is dialing in the 93 tune first. That will then in turn help with the e85 tune. So all along that intermittent smoke out the tailpipes was from a failing injector. Then the injector went completely bad.
Just make sure to keep the gas out of the starter this time 😉
Thread Starter #107
Getting the e85 tune dialed in. The 1700s idle and cruise very smooth with e85. E85 mileage with 1700s are not your friend.
Cost of e85 way cheaper and makes up for it. 93 is $2 more a gallon here
1700’s are a big injector for gasoline and idle quality on gasoline, 1300’s are the go to ID flex fuel setup injector. How much boost you running? Easy swap pulleys or??
I’ve drowned starters in fuel, coolant, and NEVER had an issue with one??? WTF on that one from your mechanic.
PS, my wife HATES my car too, she would rather walk then be terrorized in it lol 😂
A
Still doesn’t make sense on how fuel got on/in the starter. Crazy the car ran at all leaking that much fuel out of an injector
and not burn to the ground...that's a ton of fuel leaking under the hood..
