MMx two-step question
Ricky Racer
Vancouver
2018, dodge demon
I like the MMx two-step over the stage 6 because you adjust your rpm lower and it comes with a button instead of a micro switch for the brake pedal. Do these aftermarket two-step modules lock first and second gear to keep the car from moving? And what do I need to tune out the misfire circuit?
I have the MMX 2 step. It's just a rev limiter.
You will need to completely redo your tunes. I built 8 lbs of boost at 1200 rpm on the 2 step.
I plan on having them redone and attempting the 2 step again
Ricky Racer
Ricky Racer
Vancouver
2018, dodge demon
Thanks for the info unholy, looks like I will be foot braking it.
