Push Starter Button Not Enabling The Starter Motor To Engage. Advice Please
Lord Hellcat
Barking
United Kingdom
2015 Dodge Challenger SRT Hellcat
So the Hellcat has been sitting idle pretty much since the end of September when I had a clicking noise coming from the supercharger when you switched off.
We pulled the supercharger and sent the snout to Jon Bond. The pins and bushes were worn and replaced.
I asked them to check the operation of the Litens 2.85 and it was given a clean bill of health.
Back in February we refitted the supercharger and much to my distress the clicking noise was still present.
So I ordered a new Litens pulley from HHP and Liam my mechanic finally got around to fitting it today.
Thankfully the noise has gone.
Whilst laid up the battery died and we fitted a new battery.
However when you cycle the engine to run and push the start button it will not crank the starter motor :(
The Hellcat does not have an immobiliser fitted, we pulled the starter motor relay and switched it with another relay, still no good.
So Liam then tried a link wire where you cycle the engine to run, hold your foot on the brake and then use the link wire in the fuse box to crank the starter and it fires right up. You only hold the link wire in the fuse box for as long as it takes the engine to fire.
Any thoughts on what might have failed please
New push button switch
Can you shut the car off via the button after doing this?
Subbed
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
yes, button works as normal and shuts the engine off. Something has caused the breakdown in communication between the push button and the starter motor.
Possibly a body control motor. Just hoped someone on here might have experienced the same issue
I know you checked and believe the relay is good, try to buy one and replace it as a first step.
This is a brand new one to me. And you had him test with a voltmeter to confirm at the fuse box that when you push the button it’s not trying to trigger the starter relay? No codes? You need to scan
The Englishman
Newbury
United Kingdom
2018 Demon
Have you tried pushing the red button with the key fob, works if the fob battery is low
Watkinsville
Mine did this once and the key fob battery was almost dead. Replaced it and voila.
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
I hope you are right TorRed. Just been out to buy some new batteries just in case.
We swapped relays over as I think from memory three are the same.
No fault codes even with the diagnostic tool.
I tried pushing the start button with the key last night, no joy.
Worst ways we are going to rig up a push starter button in the car so I can least use the Hellcat until we find a fix.
I haven't driven it since September when the Supercharger issue started
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
New key fob batteries made no difference.
The push button functions as it should save it won't trigger the starter motor.
Relays have been swapped around, no difference.
A quick check with a multi meter it looks like it has lost the feed from the PCM to the starter relay.
The body control module appears to be sending some power to the relay.
We did try swapping back to the original PCM and still the same.
For the time being we have rigged up a starter switch button in the car so at least I can use the car.
When the puzzle is solved I will let you know what the problem was in case anyone else runs into this issue
Lilschmied
Nowhereville
If you have access to alfaOBD(I'm assuming witech is also an option) you can trigger the starter solenoid from the bcm with a test routine.
You might also have some other codes in modules from the dead battery not visible from a standard scan tool screwing things up. Do you have any other warnings popping up on the dash?
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
I do not know the make of the scan tool that Liam is using.
He did run a test routine, turning lights on, fans etc but the starter motor would not engage.
There are no fault codes on the reader or in the car.
When you go to start the car it will come up with park sensors not available or something very similar from memory at the end of the usual starting procedure
That’s a very important piece of information. The car won’t start if it doesn’t think it’s in park. This is an A8 or M6 car?
zhc
2016 Dodge Charger Hellcat
I took it as referring to the park sense system which is unrelated to the trans. There's also the "Transmission not in park" message that would mean what you're saying. That message would come up when trying to start the car if it wasn't in park or the park gear release lever was pulled up.
zhc
Long shot here but there is at least one fuse in the back that if its blown, it may cause these symptoms, fuse 33 for ignition and wireless modules. When it's pulled or blown, the key fob will not lock/unlock the car and the ignition button becomes unresponsive while the car is off.
Sounds like you're able to cycle the ignition into the run position so that's probably not it.
@Lord Hellcat is your PCM flashed to an aftermarket tune? If so, I am sure you have tried, but re-flash it??
Yeah, the backup sensors - I wasn’t sure which one they meant.
So this would be the fuse to pull to prevent theft when parked?
zhc
The car will run with this fuse pulled so there could still be away around it besides putting the fuse back in. I'm not sure.
