** Resolved ** AC air flow issue
BOCA RATON
2016 Dodge Charger Hellcat
Hi ALL,
Need some suggestions. AC issue recently started with my 2016 Charger. With auto mode at the lowest temp settings and both side synched, airflow is high on all vents and cold. The second I adjust the temp from low to 60 the air flow drops to a trickle on all vents. If I go back to low it’s back on full force. Doing some troubleshooting, if I unsynch and adjust the passenger side temp to 60 or higher air flow on all vents are the same and strong, It’s only when I adjust the driver side air from low to 60 air flow becomes a slow trickle. Search this forum but mostly getting hits for the blend door being root cause with the passenger side air blowing warm. Any suggestions before a make a trip to the dealership? Thanks.
note: all ac controls work fine when not In auto.
Hi ALL,
Well, your last statement ruined my thoughts.
I was going to ask what happened with it set on auto.
I'm sure someone here might have some inputs.
Diboblo
Riverside
2015 Dodge Charger Hellcat!
Check your humidity sensor.
If it fails, it sets a code, but not a light. You will need a scan tool.
This sensor is central to climate ops and when it goes bad (depending on how it fails), it causes all kinds of quirky behavior.
Had to replace mine about 3 years ago. No problems, since.
Sent from my SM-G666 using Tapatalk
B
BOCA RATON
Thanks Diboblo, I have couple of scan tools and will check. Is that sensor located on the windshield near the rear view mirror?
I think it's down in the box under the dash??
See below
Diboblo
Riverside
Yes
Diboblo
Riverside
68440808AA
B
BOCA RATON
Perfect, thanks.
B
BOCA RATON
68440808AA
Thanks Diboblo, the new humidity sensor did the trick.
