Thud/thumping suspension sound at low speeds...'18 Durango SRT
Tampa
2018 Durango SRT
Has anyone had this issue? Local dealer and indie shop can't seem to diagnose, other than "try replacing the struts...maybe that'll work?" (to the tune of several thousand). Couldn't find anything on this forum, so I apologize if it's been answered elsewhere. Replaced and tightened sway bar links, but to no avail. Definitely sounds like something is loose or gone bad...
Numerous threads about it here going back as far as 2014:
https://www.dodgedurango.net/forums/
Usual culprits:
loose spare
loose or defective shock (and/or shock mounting bolts)
bad shock mount
Just search that site for thumping, lots to read !
J
Tampa
2018 Durango SRT
Excellent! Thank you so much? Weird how I typed in "thumping" on the home page, and got nothing back. Appreciate your help!
Brooklyn
18 SRT Durango
Don't know if you solved the problem but the sway bar bushings can also cause thud sounds .
