What are your plans for modifications this “off season”?
Okay, I’ll start. The car is put away and is resting at about 60 controlled degrees under cameras and our residential security system as well as being basically impossible to start.
Post up your plans for modifications, maintenance or replacement parts in the next few months here. We need to talk more about cars on here!
Today I received the V-Clamps that the local shop will be welding to the cat-back exhaust pipes and on the pair of catless bypass pipes as well as a pair on the OEM cat pipes. This will enable me to change out the pipes for the track to eliminate the cats, while allowing an easy and fast way to switch them out for the OEM chit for the street. Other than this, when I decide on all my replacement tires both for the street and track, I’ll add to this thread later.
These Vibrant products have male/female flanges and are 304 series stainless steel. Unfortunately they are made in China, but look to be fairly good quality along with not very cheap!
Thread Starter #2
Reserved
Someone is in need of a low-profile, high-performance brake cooling system, I have it in mind to focus on that after the first of the year.
FI chiller, New plugs, blower eval/rebuild/replacement...potential tuning switch...
...if the blower is fubar...Whipple or Hellion thru a gutted blower.
Upgrade Head studs to ARP 625 series with Cometic MLX FireRing gaskets in anticipation for a touch of spray next year. Maybe have the heads ported while their off. Install the GForce M6 Drive shaft hoop while car is on the air. Send 3.0 Whipple back to Whipple for a warranty rebuild. Send the ID1700’s to ID for check and clean. Install a better blower belt tensioner. Install the Bang Shift Billy digital clutch release valve, install a No Lift Shift kit. Break over the 1100 wheel mark on the Dyno in the spring, get some 9 second passes in at the track before the heat of summer comes. Buy a winning lottery ticket, sail off into the sunset, live to a 100 without viagra.
I'm in desperate need of some axles . I'm looking at GeForce outlaw units . While under I may install a set of 3.09,s to help compensate for the 315/50/17's .
I have some minor suspension work to do .
I also need to make a better intake system to seal to my hood .
Sent from my SM-S901W using Tapatalk
Make it happen! More than just “someone” will take upgrades to these brake systems. Now that mine runs nearly dangerous good, I will need even better and cooler brakes to chase others.
Just some beadlocks at this point.
Axles are on the horizon.
Maybe someone will develop a transbrake for these cars?
Still up in the air removing the seats. Storage is the main issue.
Just acquire more tires if possible!
No chit, if they quit going up on price maybe that is two of us!
Mantic triple
f14 front runners w/ mt sportsman
MS109 tune
