60ft Help
Good luck and keep going #20. I will learn from you.
Good Evening All,
One last thing. If you are running 10.99 at any NHRA track. Please put NT on your window and turn off the boards and almost every track will let you run without a cage. Trust me, we do it all the time. Just don't show up the track and display a 9 or 8 second pass. LOL! :) They will ban you. Just be cool and turn off the boards without a cage.
Do you mean 9.99? our cars are legal in the 10's
Dman007
6 Second Best E/T
Smyrna
Here are the rules. But in short, we break 11 seconds and we are required to have a 5 point harness and full roll cage when we trap over 135. Thus put NT on your car and turn off the boards and almost all NHRA tracks on test and tune or private events will let us run under 11 seconds.
Here is the catch; if it is a sponsored NHRA event, like bracket racing for points...NHRA tracks will not let you run under 11 sec.
Now with nitrous; make sure you wear your gloves at NHRA tracks. Some tracks make you wear a full fire suit. The starter will back you off the track when you purge and don't have gloves on.
10.99 1/4-mile (6.99 1/8-mile) or quicker:
-5-point roll bar is still okay to 10.00 1/4-mile (6.40 1/8-mile) in hardtop / t-top with un-altered floors, firewall and frame rails (wheel tubs are okay). If the floor and/or firewall has been modified, then a full roll cage is required beginning at a 10.99 e.t. or any vehicle running 135 mph or faster (regardless of e.t.). The roll cage must be constructed of a minimum o.d. mild steel or chrome moly tubing (moly can be a smaller o.d and is lighter but more expensive), see diagram below for specs. Roll cage must be padded anywhere the driver's helmet may contact it while in the driving position, see diagram below for specs.
-Convertibles require full roll cage at 10.99 and quicker.
See diagram below.
-aftermarket axles with positive retention (c-clip eliminators)
-Transmission shield SFI Spec 4.1 at 10.99 and quicker or 135 mph and quicker (blanket is okay, no expiration date)
-Harmonic Balancer SFI Spec 18.1 (no expiration date)
9.99 1/4-mile (6.39 1/8-mile)/ 135 mph or quicker:
-Roll cage is required on all vehicles at 9.99 and quicker or any vehicle running 135 mph or faster (regardless of e.t.). The roll cage must be constructed of a minimum o.d. mild steel or chrome moly tubing (moly can be a smaller o.d and is lighter but more expensive), see diagram below for specs. Roll cage must be padded anywhere the driver's helmet may contact it while in the driving position, see diagram below for specs. Roll cage must also be certified by NHRA every 3 years and have a serialized sticker affixed prior to participation. This style of cage is good til 8.50 1/4-mile times, then a funny car style cage is required.
See diagram below.
-Window net required (can be ribbon or mesh, no altering allowed unless done by manufacturer. 2009 NHRA rule book states mesh nets carry a manufacturer date and a 2 year expiration/re-cert, while ribbon are good forever. Check with your local track or division).
-NHRA competition driver's license required, done by car designation (dragster, door car, etc). A physical, 2 NHRA licensed drivers to witness/sign your forms and a minimum of 6 runs are required. For NHRA license form click here: www.nhra.com/contacts/forms/licenseapp.pdf, for NHRA physical form click here: www.nhra.com/contacts/forms/physical01.pdf
-Flexplate SFI 29.1 and shield SFI 30.1 required (no expiration dates listed, but I believe the shield is 5 years)
-Protective Clothing (SFI jacket and pants with a 3.2A/5 rating, gloves and neck collar, no expiration date)
-Battery cutoff (regardless or whether battery is still up front or relocated to rear of vehicle). The cutoff switch must shut down everything electrical when off; see here for pictures and a wiring diagram: www.ls1tech.com/forums/drag-racing-tech/733951-battery-disconnect-switch.html
-A full-face helmet is required with a minimum Snell K98 or M2000/SA2000 rating. Helmets last 12 years from their rating date (example a Snell 2005 would be good until 1/2017). Shield is permitted, and modifications to helmet or shield are prohibited. This rule posting is as it applies to cars like ours (closed body type). For open cars a different helmet ruling is required.
-A engine diaper is required at NHRA national and divisional races, local races vary, check with your division or track.
Parachutes:
-Required at 150 mph no et restriction
