390 * 34mm Rotor Rings (Rings only, no hats/hardware) REF: P/N 6818 4587 AE
Trader history for BULL (2)
Thread Starter #21
Price reduced again (and last time).
Thread Starter #23
10lb-ft
With a 1/4" tq wrench!
Do NOT use a 3/8" drive wrench!
Do use good tq wrench technique!
10lb-ft
Thanks Bull, good to know for the future.
Thread Starter #25
Pending
McLovin
Syracuse
2015 Challenger Hellcat
Just stumbling across this now...
If your pending falls thru, I would be interested....
Thread Starter #27
It did fall apart.
Blown7
Woodstock
CT
2018 Trackhawk
If only I knew for sure these would fit a Jeep GC Trackhawk.
I'd buy in a second, but the part number doesn't seem to cross match
Thread Starter #29
I believe they use a 380mm diameter ring, which is obviously different.
The DSRT also uses a 380mm and I can't for the life of me figure it out, the only thing I've come up with is that they want a larger clearance between the caliper and the wheel.
(Presumably because the vehicle might be exposed to a "dirtier" environment?)
Thread Starter #30
Sold!
