It won't pole vault.
It’ll only pole vault if it breaks at the trans side?
So I should have 2 loops since it’s a 2 piece shaft?
I always wondered that myself. Now I have a 1 piece.
Yep. It can lodge into the pavement.
I'm not going to debate but safety should be your #1 priority.
True, but honestly I’ve had just about every bolt on the car undone, I’m surprised the wheels even stayed on going down the track 🤣
pretty sure engine mounts are hand tight lol
Honestly more worried about the flexplate coming loose than driveshaft breaking, when I was putting it on didn’t have anyone locking the crank or a proper tool. Also didn’t realize you could just put a screwdriver through the holes in it to lock it while you torque the crank bolts. I’m sure it’s fine ish
My transmission mount has a Walmart sticker on it (yes ordered from Walmart.com, might be Chinesium)
Unholy we gotta teach you what the post edit button does :ROFLMAO:
The exhaust will catch the drive shaft at the trans end so the car won't pole vault. A broke drive shaft becoming a buzz saw I can't speak to but I'd rather it not break at the diff, blow through the fuel tank, and cause me to be burned a live.
run Forrest, run!
No locktite?
They had some on there, were brand new Oem bolts so had the blue stuff on the threads already. Which are shorter than the crank bolts for the m6 flywheel btw. But I had the blower off and intake ports open so engine turned over pretty easily
They had some on there, we’re brand new Oem bolts so had the blue stuff on the threads already. Which are shorter than the crank bolts for the m6 flywheel btw[lock titer?
You're just fucking with us...
You're just fucking with us...🤣🤣🤣
What lol I’m being serious lol. They ship bolts with threadlocker on them already depending on what they’re for
Does this help if it breaks at the diff as well?
No loop is in the front. Diff breaks you have a mess still
I’ll get a hoop eventually l. Just one more piece to take off the car
All this over a $200 piece.
Never said it wasn’t a good thing to have, just don’t have one
Thread Starter #1,298
well you should, mine saved my undercarriage, was damaged and been putzing with it to get it to fit over adapter and new shaft
I have a 2 piece, I imagine if it went at the back the carrier bearing mount points would keep it in place, and if the back went bad the rear half would still screw stuff up anyway.
Thread Starter #1,300
D9C80394-11A6-4154-BDD6-18A27534C2FE.jpeg 3771C141-76F0-44A4-BF4C-4C8DCE2DE2C2.jpeg CECCF91E-6815-4BFC-8ABC-7B5AA6FDB57C.jpeg
Front and rear broke. She was sent. I have a copy of the obituary:
Today we pay remembrance to my DSS one-piece. Born September 29th to @fumanchu182 and @HighHorseman . A resident of MIR, Cecil and Capitol, the drive shaft is survived by a 2015 Hellcat, 2016 Dodge ram and the drive shaft shop. The driveshaft was a ardent supporter of burnouts and quarter mile passes for three race seasons. Viewing services will be available till 3/13 when recycling will collect. 🫡 🇺🇸​
However super easy install. The hoop was damaged so ill be ordering another one soon. Better it than my undercarriage.
F691C1D5-205C-4D9B-9BAF-C04F50D94D62.jpeg 22ECCB47-26CF-4133-ACF5-E2EB46503FE2.jpeg
3.5 inches from edge to edge, fully in spec.
