D
Thread Starter #241
D
Thread Starter #242
Chipper Browns Chrysler. Look what's on the back window.
That is the top fuel car that I was a pit gopher for way back.
Haven't seen Chip in years, he was a partner in the car.
Brings back so many great memories.
D
Thread Starter #243
D
Thread Starter #244
Demonic Cat
Mid
RI
2019 Hellcat Redeye
Always liked and respected the T Bolt’s. Bobby Tasca helped develop it with Furd. Classic style, power to weight ratio 427 side oiler with teardrop hood.
Only factor racing Cars I liked better was of course our brand, the lightweight MOPAR’S. That gave them a big problem
ie: lightened factory race Hemi’s of that era. And now of course the 170
Original headlight ram air?
Demonic Cat
Mid
RI
2019 Hellcat Redeye
Yep that be it.
D
Thread Starter #249
D
Thread Starter #251
Just not sure if they were the first.
I think Pontiac used it in the real early 60s?
D
Thread Starter #252
Demonic Cat
Mid
RI
2019 Hellcat Redeye
Norm Krause place.
Demonic Cat
Mid
RI
2019 Hellcat Redeye
Blow off valve? Not sure, why would NA engine need one?
initial guess no
Demonic Cat
Mid
RI
2019 Hellcat Redeye
Based on picture ^^^ with many white hats, I would say Norm promoting the Dodge White hat Special for spring of 1969.
D
Thread Starter #256
initial guess no
If under certain circumstances too much pressure is created causing a backup in the carbs. A pressure relief valve type of deal.
The 6 pack cars had water drains which did the same thing.
Id think that’s built into the center section, that’s just meant to be a cold air intake like the hellcat air box basically or the redeye hood, just trying to direct cool air from outside. You shouldn’t have that much pressure from going fast
I need to do something because IATs at idle are hotter than stock with a JLT intake. I might have to come up with a different solution
D
Thread Starter #259
D
Thread Starter #260
Heat exchanger. Everyone says they don't work...I don't listen to everyone else.
