Did another drag strip day last weekend, won my first race, lost the 2nd. Class racing event, broke out as usual lol
Finally installed real rear seat closeout
That's nice.
I watched the vid on removing the belts! Yikes! I'll hold off on that until maybe next spring!
BTW: Seeing carpet with no dog fur kinda looks staged to me! :ROFLMAO:
Yep miles
Not kms
It seems less when I say miles LOL
I put 500 on it this year which is the most since 2016
Yep miles
Not kms
Please leave a message to your widow to contact me about buying the car. Thanks! ;)
WTF...like yer gonna out live beer guzzlin Tie guy....did you forget how old ya are..:unsure::unsure::unsure::unsure:;)
By then it may have 3000 miles LOLOLOLOL
No prob, that'll just lower the price 20-50%. I'll still take it though. :(
Decided to rotate the tires. Dragged out the floor jack, impact, and stands. Then I thought, "You dumb ass. You screwed up your back so badly in June, you're just now getting better. Let Discount Tire do it for free." So, I listened to myself and put everything away.
Why do you need stands?
Check the torque.
Check the torque.
I usually put a stand in the front and leave the jack under the nub in the rear.
Always do, but I watched them use nice split beams to do final torque settings.
Ah, you need 2 jacks, well, for you, not anymore.
I put the heavy jack in the front which partially lifts the rear also. Then I put the $69 HF lightweight in the back. I use the pucks front and back. If there is a quicker and easier way, I'd like to hear it! :)
Tomorrow the DR's and skinnies go on, fuel purge and add 100 octane, remove pass seat, etc., for Track Rental Friday.
Li
listening to yerself has value....talking to yerself..(and answering)...is a whole nother dynamic...:eek::rolleyes:;)
There is...just drive it up on the lift..position the scissor table under the tire....the heaviest thing you will lift....the impact gun...work smarter..not harder;)
Yeah, If I was thinking ahead, I would have put a 16' ceiling in the barn when I built it, but too late now. :( 10' doesn't cut it.
I have 2 lifts...(don't know how I lived without them)
Yeah, rub it in.... :)
@ 71..my layin on the ground days are over...even detail jobs are a breeze...no more bendin over
That must be your way of saying that you do not.
But I can relate to the lack of garage height. Had the one in California built to accommodate a 1-ton pickup with a camper, since I'd never have anything taller than that.
Which I didn't until buying a Peterbilt a couple of years later.
I have two 2 ton aluminum jacks but changing wheels i use one and go around the car. Takes me less the 20 minutes to go from street to drag tires. Probably could knock off a little time using both on one side but fine using one
I tweaked my back a few months back..(nothing serious)..acts up now and then...I'm done bendin over...I've done physical work my whole life...don't wanna end up a cripple...now I wont even pick up change on the floor:giggle::giggle::giggle:;)
