Paragon 400mm rotors
TrackDay
Great White North
2016 Dodge Challenger
Has anyone tried these in an aggressive road course scenario? Since I need to replace my rotors for next year anyway I'm considering a move to the 21+ rotors and this looks like a reasonable option since I don't have a 21+ factory center hat.
https://paragonbrakes.com/2-piece-r...34mm-21-dodge-charger-challenger-srt-hellcat/
I have the ACR calipers so it's just a different spacer for them and I can use the larger rotors.
rayzazoo
Somewhere
Hellcat
I've run fronts for ~1 year. I swapped from the NOA Brembo P37018N to the non-NOA Brembo P37018 shortly after a few drives. The braking difference was noticeable since the NOA are ceramic based vs non-NOA semi-metallic. Unfortunately, I haven't had them on a road course or with track-focused pads.
From a weight perspective:
OEM Hat: 1.8lbs
OEM 390mm: 29.2 lbs (31 total)
390mm: 25.6 lbs (27.4 total)
400mm: 26.3 lbs (28.1 total)
A few pictures here
https://www.hellcatforum.org/threads/paragon-brake-rotor-rings-oem-hat.15704/#post-448564
There's also https://www.ceramicdisctech.com/ and still in development.
TrackDay
TrackDay
Great White North
Thanks for the feedback.
rayzazoo
Somewhere
Hellcat
You're welcome, and it would be great to see a track comparison of Paragon versus Demon Performance rotors.
You mentioned Viper ACR calipers. It's the same rotor/caliper size as the 2015-2020 Hellcats, but with the benefit of lighter/prolonged heat transfer titanium pistons (~2 lbs savings per front caliper).
The 2021+ cars have 400mm rotors and that's ~16lbs added in unsprung weight vs 2015-2020. Wesley Motorsports had a 2021 Charger Redeye and venture to say that is why the opt'd for the Viper ACR Caliper/rotors; 400mm to 390mm and piston benefit.
Material:
Demon Performance: proprietary cast iron
Paragon: CM-250 special formulated high carbon alloy cast iron
400mm rotors
OEM: 38.65 lbs (with OEM hat)
Demon Performance: 30.75 lbs (with DP aluminum hat)
Paragon: 29.7 lbs (with Paragon aluminum hat)
390mm rotors
OEM: 31 lbs (with OEM hat)
Demon Performance: 25.39 lbs (with DP aluminum hat)
Demon Performance: ~24 lbs (rotor ring)
Paragon: 27.4 lbs (with OEM hat)
Paragon: 25.6 lbs (rotor ring)
360mm rotors (SuperStock/Demon)
OEM: 22.6 lbs
Demon Performance: 22.6 lbs
Brake Pads
Hawk DTC-70
  • Type: Motorsport-grade race pad
  • Material: High-performance race compound
  • Friction Coefficient (μ): 0.80 ~ 0.90
  • Operating Temperature Range: 400°F to 1,600°F (204°C to 871°C)
  • Optimal Temperature Range: 800°F to 1,200°F (427°C to 649°C)
  • Torque: Extremely high
  • Initial Bite: Aggressive and controllable
  • Modulation & Release: Superior
Paragon PBP690T6-15 R7
  • Type: Advanced high-speed track/competition pad
  • Material: Metallic
  • Friction Coefficient (μ): 0.48 ~ 0.53
  • Operating Temperature Range: 212°F to 1,562°F (100°C to 850°C)
  • Recommended Use: Advanced high-speed track events, competitions, and heavier cars requiring maximum braking performance
Brembo P37018
  • Material: Low-Metallic
  • Friction Coefficient (μ): 0.35 ~ 0.45
  • Operating Temperature Range: -40°F to 1,200°F (-40°C to 650°C)
https://www.hellcatforum.org/threads/demon-performance-rotors-for-road-courses.13473/page-2
TrackDay
TrackDay
Great White North
Thanks. I'm not too concerned about weight of the rotors. My focus is at least getting a little more surface area and thus heat capacity in the rotors to help me avoid brake fade. At Road America I can fade the DTC70 in 2 hard laps. I have a set of DTC80 front pads that are still in the box, waiting for the next time I think I've changed the hardware enough to possibly move the needle.
I know 390 to 400mm is a small difference, but it's an easy experiment when I replace the rotors.
Given your ability to move your calipers out to accommodate 400mm, I'd do it..
.25
rayzazoo
Somewhere
Hellcat
Paragon could perform similarly to GiroDisc/Demon Performance. Maybe benefit/tradeoff is Paragons are 2lbs heavier, indicating more material/heat capacity. Would need to test.
Thoughts on directing cool air to the rotors aside from the updated belly pan with brake ducts and additional air deflectors?
Could double the size of the current brake deflector by overlapping with another kit.
Or attach brake duct to the current brake deflector from the underbelly duct:
Perhaps adding something fabricated like a dust shield with brake duct tube (visual reference below) and attaching it to the caliper bolts (red). The areas in blue used to be the dust shield mounting points for the older SRTs with smaller rotors.
Let’s try to go over to RA in May for MPV’s weekend. FYI that is one of things I really want to do next year, along with running one or more Donnybrooke.
Anyone have a solution as to how to mount those brake ducts on the AAD suspension parts?
TrackDay
TrackDay
Great White North
Mine is a 2016 but I added the underbody ducts and the control arm deflectors as you show. I made the deflectors at least twice as large with some sheet metal that I shaped to bring more air in. They are attached with the deflector screws.
I have struggled how to get more air in there. I have leaned towards some 12V duct fans and have them on the shelf if I get driven to experiment, but even routing and attaching a reasonable hose and tube to direct air at the center of the rotor has stumped me. I'm no fabricator.
TrackDay
TrackDay
Great White North
I may be ready to try it.
TrackDay
TrackDay
Great White North
Are you running the AAD lower arms too?
TrackDay
TrackDay
Great White North
I never did finish the prototype, you laughed at the pitch/sound... ...hurt my one feeling... :unsure:
If you think there's something there, I could work on it again this winter...
TrackDay
TrackDay
Great White North
My main road block is how to mount a duct and direct it to the center of the rotor.
Onur Can made something for his Charger but it went to the rotor surface. Not a show stopper but not as efficient.
This approach has a rigid SS center duct piece nested inside the rotor that has a 2in flexible duct, routed directly to the I.D. of the rotor vanes. All airflow is directed through the rotor, not just at it.
This would mount under the 2 (of 3) hub bearing bolts. (We discussed the downsides of this once before )
Their heads could/would be cross drilled for safety wire.
The subassy above mounts to the inner surface of the well, somewhat behind the strut, so its intake is facing up to the top of the wheel well, 2in flexible duct between the fan and rigid portion.
So glad the only thing I worry bout...is brake dust...:giggle::giggle::giggle:
