Lithium ion battery for the Hellcat
20HCM6 22RENBS2
Sorry for the ignorant question:
What do you need to do differently with a LIon battery to maintain it? Do you use the same charger? Same float/trickle charger? Is it ok to leave the float charger on all winter?
There are Lithium-specific chargers/tenders that you should use. If the battery has its own BMS circuit then a standard charger/maintainer should suffice.
My Walmart battery is going strong. Battery has been disconnected for over a month. Car sits all the time. Not a bad replacement
Car sits all the time:unsure::unsure:...dirtiest garage queen I ever saw ..:oops::oops::oops:
You only say that because you haven't seen mine.
MJS73
Moparland
2020 Challenger Hellcat
Good thread to keep going. Since my dad bought a T/A he wants it faster. Looking through here on batteries and going on amazon and it looks like a lot more options and cheaper prices. Could barely get one under $400 a few years ago
@Taxinator posted the battery he bought and @catdad @DGatzby and is still under $270 Stock demensions and weighs 20 lbs. The Stock battery is 44 lbs.
https://www.amazon.com/LiFePO4-Batt...=B0CXXVT7V5&ref_=pd_bap_d_grid_rp_0_77_t&th=1
I might have to get one to offset the additional weight of going from et street fronts to sportsman's
I gave $389 in Aug ‘24. $259 now.
I wouldn't touch any LiFePO4 battery without first witnessing a teardown video showing it actually has a BMS circuit.
PowerTex claims to have a BMS but do /not/.
* Last winter “stored” - charged it 1 time/mo. Never a hint of a problem.
* This season - zero maintenance and great performance.
Really can notice the weight off the rear right, it rips the starter each time with authority, never all season even after sitting two weeks or so didn’t ever say it did not have enough power for cool down.
Glad I purchased it, now enjoying it, never worried a minute about a problem myself.
I weighed it out at 17 lbs.
Was thinking the extra weight of the stock battery would be better than losing that weight of the right rear tire...
269 now and wish I knew that before buying a agm for my mustang would have tried that instead
I don’t understand.
I do not care where the weight comes out, mine will take it. Lighter is better for us.
I don’t understand.
Why is the car faster with people in it?
It shouldn't be any faster, or slower. Weight really have nothing to do with top speed. It'd take longer to reach that speed, but it'll be the same.
20HCM6 22RENBS2
I've been told by HC racers that a heavy battery is fine as it helps with traction. Lowering weight in the front is what makes a big difference. I removed the front sway bar and made 4 new PB's! Best was .07sec better! (9.993 down to 9.921)
I would be interested in any actual before/after results from a battery change.
Maybe just keep fewer volts in the stock battery?
Not that I know how much a volt weighs.
20HCM6 22RENBS2
Hell! Put a MC bat in and use a jumper to start the car! Like some airplanes!
I am not after the quickest ET. I have not even drag raced it.
