HangZhou
China
I run the track inserts on mine. I can only feel it on take off. You probably have another issue.
So I bought the track edition hard rubber mount. I'll install it once it arrives and give it a try—hopefully it solves the vibration issue.[shakehands]
Make sure the mounting bolts to the body are tight. Another remember had the same issue and his bolts were loose
HangZhou
China
Thank you very much! I really appreciate your input, and I'll be sure to pay close attention to all the points you raised. [shakehands]
Good news: The rear boot on the driveshaft has been repaired, and we've fitted a JXB carrier‑bearing bracket.
Bad news: The driveshaft vibrates violently between 68–80 mph, and I'm not sure if that's due to the street‑spec bushings I bought being too soft. I plan to buy a set of track‑spec bushings and swap them in to see if that fixes the problem; otherwise, I'm considering replacing the entire driveshaft.[dunno]
I didn't realize their was different bushings. I got one and there wasn't a choice. Still haven't installed it or the red eye driveshaft yet though
Nothing.
Fkrs still in the shop.
Starting to go through withdrawals
Got an email at 12:30 this afternoon saying car was ready.
F@*&k!!
Sipping on a glass of infinity whiskey, and said fk it, calling them to see if cat is ready.
They said yes.
Just saw the email at 4:45.
I could been a contender, I could been somebody.
I COULDA HAD MY CAR HOME if I woulda seen the email.
F@*&k!!
They said yes.
Things happen for a reason.
I've been checking the cars location with unconnect and it's always been in their garage, checked this afternoon and saw it in the parking lot (reason for the afternoon call).
F@*&k!!
They said yes.
Will make this morning even more fun getting her back!
F@*&k!!
They said yes.
What are you sayin ????..instead of a Champ....yer a Chump???
Got her back this morning.
SOUNDS GREAT!
SOUNDS GREAT!
Weird how my wp replacement made the car feel new again. I guess I was getting used to the extra noise.
Just curious Hunter, I know yours was warranty work, but how many hours were charged to Stellantis on the invoice?
No hours s
No hours shown on invoice, just states "Warranty" next to techs name and items.
Replaced 3 idler pulleys, water pump, Aux pump, antifreeze and aux coolant.
They had car for 10 days (and put 3 miles on it).
Tech stated that car was retested.
Changed the oil. I bought enough oil to do 2 oil changes this year with the Driven GP-1. I'm at 3200 miles since getting it out for the year. Still had a green look to it while draining
Put stock wheels on (front) so I can take my triumph wheels in and have my new tires installed.
The PS4's that are on the wheels right now only have 11,000 miles on them, but are 7 years old (and look it- cracking).
Just replaced the rears 4 months ago with Nittos, so decided to go with Nittos on the front as well.
I got nitto's as well all the way around...DR's on the back...
The PS4's that are on the wheels right now only have 11,000 miles on them, but are 7 years old .
Nice that somebody is paying attention to the date codes, nor just looking at how much tread is left.
Replaced my OE tires because the date code was 8 years old.
Plenty of tread left & no visible cracking or rubber chunking off, but figured it was not worth the risk to keep 'em.
When I realized that the tires I'd put on my '18 very early on were seven years old, I didn't dare exceed 60 mph the time I drove it before its new tires arrived.
And when seeing that two of the "new" tires were already almost three years old I returned them. Not going to risk collateral damage resulting from old tires...even if the still look like new, which my old ones did.
