Redeye upgrade
I'm not sure on that. The description in HPT isn't much help. It says "Maximum input shaft torque limit during slip". But I don't know what "slip" is.
Factory 2016 Hellcat is 443 for that value and the factory 2018 Hellcat tune file doesn't even have it, or at least not in the same spot in the cal.
Markp
Fuck Trudeau
Not understanding "max torque limit slip". Does that mean the Demon allows a certain amount of slip up to 959 then has max pressure and the RE does the same up to 339 then adds max pressure? Thanks.
Is this not because the Redeye doesn't have the transrbake?
I thought maybe they delayed max pressure to alleviate driveline shock/ breakage and launch control on the Demon , being it was released as basically a dedicated drag car. Although that would be harder on the clutches. I have read the A8's are basically the same but the Demon has a looser converter. Surprised that even the other settings were the same.
2021 redeye
Thanks for the reminder. In HPT the templates are more advanced in the 2019 RE tune I have vs the 2018 Demon. What this means is I can see more data so I wasn't able to compare everything 100% but the things I could compare everything was the same between the Demon Crate and Redeye trans settings. Shift timing, pressure, RPM, etc.
There was one setting that was different. Max torque limit slip is 959 lb-ft for Demon and 339 lb-ft for 2019 Redeye.
In my personal custom tune for my car I have that value at 959.
I know its bee a long time. Has anyone figured out what that Max torque limit slip table does?
