1320 sway bar part number?
Looking for the Challenger 1320 front sway bar part number and weight. I have found this 68184221AB but not sure that is it
I can't answer your question but not sure if the swap is worth the time & money, just take the bar off, I did & as long as you drive easy on the street around corners, can't hardly tell it's off.
I want to keep the sway bar on. My Daytona sway bar weighed 14 lbs. If the Hellcat weighs more (I will take it off and weigh it) and I can save 10 lbs, it is worth it to me. Now 5 lbs maybe not so much
That's about what you'll save is 10lbs.
Stormtrooper1320
Bran
Romania
Panzerkampfwagen 150
If you ask @why2kmax , he can probably get you the number off of his.
My 2018 hellcat challenger front sway bar weight 20lbs
HWDan
Home of the Hellcat
2017 Charger SRT 392
Hellcat front sway bar diameter is 34mm right?
I think the SP WB has a light weight hollow bar, also 34mm and 11 lbs and change I remember reading somewhere.
HWDan
Home of the Hellcat
68386844AA
not sure that is it by what it says
New competition sway bar found on the 2019 Wide Body Scat Pack only
I will be calling Steve White and see what they say the part number is but would really like a 1320 owner to see what part number is on their car. I have posted this else where also so at some point we will all know
HWDan
Home of the Hellcat
HWDan
Home of the Hellcat
68386844AA
Right, that's the WB Scat Pack one. I would assume the 1320 one might be a smaller diameter so you'd have to add in the smaller bushings and mounts. Could be a pound or 2 lighter as it's supposed to be hollow as well.
For some reason when I go to look up models for part numbers like Tascas site, 1320 isn't one of the models listed
But I found this:
68184221ABStabilizer Bar
W/ O AWD, DRAG RACE SUSPENSION
$109.09
it also says in the notes: includes bushings
It is possible Dodge is using a light weight bar that has been around on other models also. Find the lightest bar they already make and throw it on there
I actually have one laying around in the “stuff” pile at the shop. I bought the complete spring and sway bar set for my car and did not install the front. It came as part of a Scat Pac 1320 drag spring package that included front and rear sway bars. I got it from Steve White. The front Hellcat sway bar weighed about 25 lbs when including all the hardware that gets removed when you don’t run one. I didn’t weigh the 1320 bar to compare with the Hellcat.
I'm thinking the Demon and 1320 use the same bar
VICTORVILLE
That's it. SDT order code = DRAG MODE SUSPENSION.
A friend I walk and ride bikes with every weekend has a 1320 at the shop he helps out at and was able to verify the part number 68184221AB
Just need a Demon owner to tell me if that is the same part number on their car
