2019 Charger Grille install
I did this write up awhile back and thought I would move it here. There are videos on how to remove the front so I'm not going to get into that. It took a little over 3 hours. The lower grille is bolted in so it went pretty good. The upper grille has tabs holding it on so it takes a bit to get each one unattached to get it off. There are also 6 push pins holding it on. There is a different kind of push pin on the lower part on each side. At first I thought it was a small bolt but there is a round plastic pin that I had to use a punch to hammer it out. Can't say I have ever ran across them before. I also had to cut a small part off my air inlet so the new radiator shield would fit. Using a cutting wheel it took all of 1 minute to trim it.
grille 1.jpg grille 2.jpg grille 3.jpg grille 5.jpg grille 6.jpg grille 7.jpg grille 8.jpg grille 9.jpg grille 11.jpg
Thread Starter #2
Total cost through Steve White was just under $200. I already had the air inlet so that dropped the price from someone that would need it. Here are some of the prices from Steve White
A couple of links with part packages
2019 Dodge Charger SRT Scat Pack Daytona Hellcat Ram Air Box & Tube Shield OEM (SWMHCBOXLD) | Steve White Parts
2019 Dodge Charger SRT Scat Pack Daytona Upper Grille with Bezels Dual Inlets OE (SWMSRTGRILLE) | Steve White Parts
2019 Charger SRT Grille:
Grille- 68417502AA $51.33
Lower Grille W/O adaptive cruise control- 68394592AA $45.78
Lower Grille With adaptive cruise control- 68394591AA $46.37
Bezel Upper Grille Right side- 68417504AA $13.75
Bezel Upper Grille Left side- 68417505AA $13.75
Radiator left side shield Hellcat- 68394595AA $9.44
Duct-Air Cleaner Hellcat- 68424623AA $60.89
Lower Bezel Grille Right side- 68417498AA
Lower Bezel Grille Left side- 68417499AA
Nameplate Daytona- 68420463AB $44.84
Plasticman
Opelika
AL
2016 Charger HC
I just completed this mod this weekend.
Rob
Austin
2017 Charger Hellcat
I search the part numbers I had and found nothing so I updated the list with the new ones
Thanks
