before spacers and after spacers pics.
gates belt 100594
2.85 upper
incognito sleeve
stock tensioner
Failing to see the significance? Why do you need to run spacers?
because I wanted to that all the reason I need....that and the belt is a little tighter also and with the blanket it also lower my temp. on i/c
Apologies, I thought you meant spacers on the pulley and sleeve. LOL, I run the FI spacers as well, they are awesome.
Looks like it didn't move
thats ok I guess it's my fault anyway....you know how we assume.And yes sir your right my i/c temp on a 90degree day stay around 90-96 unless I drive it hard and then they'll climb but come down soon after
very darn little put the spacers are only 10mm anyway.But every little bit helps
I did idler pulleys (slightly bigger) and spacers so mine way off a bunch so I changed the belt
thats what I was going to also but it dont slip and and it is close might be a little tight but not by much
