Best Oil for Non High Performance Daily Drivers
This stuff is amazing and no other oil cleans like this. Wear properties are great, too. The Oil Geek is a degreed tribologist. Many accounts on BITOG of it stopping oil burning on high mileage vehicles.
4oz of Swan dish soap works wonders for stuck rings...(been using it for years):p;)
Been using it in my Jeep and the Challenger. Valvoline has been my other oil I have used for many years so when this came out switched to it
I’ve been a Mobil 1 guy for decades now. I run it in all my ice’s. Haven’t had a reason to switch just yet, but above looks good.
Started using it my Grand Cherokees.
i’ve been using Valvoline full synthetic in all my vehicles for 30+ years now. every forerunner I’ve had had over 300,000 miles on it and it failed because of frame rot not engine or drive train issues. All Looked brand new inside. I use Valvoline restore and protect in everything now since it came out.
This is my previous 4Runner when I did head gaskets on it. It had just under 300,000 miles on it. It saw mostly highway mileage at high speed and a lot of WOT driving, it had no carbon in it at all lol it was this clean upon tearing it down, intake valves, piston crowns, cylinder chambers. Look at the cross hatching in the cylinders, like the day it was honed after 300k miles. This ran on Valvoline 10-30 Max Life Full Synthetic its whole life. Restore and Protect is even better now!
IMG_6581.jpeg IMG_6572.jpeg IMG_6542.jpeg IMG_6548.jpeg IMG_6540.jpeg IMG_6536.jpeg IMG_6543.jpeg IMG_6545.jpeg IMG_6557.jpeg IMG_6550.jpeg IMG_6541.jpeg IMG_6538.jpeg IMG_3567.jpeg IMG_3570.jpeg
Really. Heard trans fluid in the engine does the same thing.
View attachment 178860 View attachment 178861 View attachment 178862 View attachment 178863 View attachment 178864 View attachment 178865 View attachment 178866 View attachment 178867 View attachment 178868 View attachment 178869 View attachment 178870 View attachment 178871 View attachment 178872 View attachment 178873
Cleanest engine apart I've seen nice work
My friends dad did that one time back in the 80s. There was so much smoke someone called the fire department thinking there was a fire:LOL:
Interesting to hear Valvoline recommended. Years back it was accused of sludge.
I use Penzoil Full Synthetc in all of ours. Used to use Penzoil Platinum but testing showed full synthetic was as good or better and like $22 for 5qt at Wally World. 4runner is at 170k miles and climbing.
Wow, what did you usually run for fuel?
High tier Pump 87 but I use Royal Purple max clean injector cleaner at double strength every 3rd or 4th tank as using it always gave me three or four MPG more when it was in the tank I don’t know why, but it’ll always did
Valvoline Restore and Protect we clean up those engine internals in three or four cycles. You’ll notice on drain your oil will be a reddish color and when that reddish color disappears, your engine is clean inside. For the first run of it don’t go above 2500 or 3000 miles or change the filter during the interval because if you cut the filter open, you will find a lot of sludge in it most likely. The stuff really works. I’ve seen videos where they’ve run engines constantly for months, and tore them down and tested them to test and perfect restore and protect, first formulations were actually too aggressive, and they tamed it down some because of the filter clogging issues in really dirty engines.
My last 3 vehicles, 04 GTO, 03 Silverado 5.3, 04 Wrangler, all went 145kmi+ on conventional oil. Only prob was the Wrangler had an occasional tick, the back 2 lifters had a reputation for getting gunked up. Changing to synthetic fixed that.
It is nice to see companies developing super oils but I cannot imagine any circumstance where anyone would see a difference in normal driving for 150kmi. Especially when lunitics like us change every 3kmi.
My current favorite is Mobil 1 0w40 for $28/5q at WM and AMZN. I figure for the new truck and Wrangler, they should be fine for the rest of my life.
The HC's get PUP.
Back in the day, friend had a late 70's (79 I think) Pontiac, the subject of oil changes came up and he said he hadn't changed in 10kmi or so. I strongly urged him to get it done.
Couple weeks later he said he got it changed, and said, "I'm embarrassed to say, it had been 46,000 mi since the last change". :ROFLMAO:
Daily drivers can go a very long way as long as they have fluids, air, brakes, etc. Unfortunately that is too much to ask from many owners.
Next we need to discuss coolant flush! Some people say every 2 years, I say change once, somewhere between 5 and 10y!
Let's not go into trans fluid...;)
The HC's get PUP.
You might not ever have to change oil for the rest of yer life....(after all yer closer to the end...than the beggining..[xx(][xx(][xx(] [unsurelaugh] )
Radiator...trans..[scratch]..lets not get carried away now...[screwy][screwy] [giggle][giggle]
Thread Starter #18
Pretty strong BITOG testimonial. These engines are hard on oil.
“I've never used HPL before myself. A couple of guys on AudiWorld forums have claimed to used HPL when they begun to consume some oil on their Audis and claimed to reverse the consumption because they were scared of using VR&P and wouldn't think outside the box worrying about approvals, even though HPL has no VW/Audi approvals either.
Most all of us on AudiWorld forums that have had or are having oil consumption issues are using Restore & Protect even though it doesn't meet the specifications required from Audi. All of us that are using VR&P have been extremely impressed and will continue to use it at up to 6000 mile intervals. I'm on my 4th run of VR&P now and will continue to utilize it on 6000 mile intervals forever. One fella has over 60,000 miles using VR&P 5w/30 in Texas on a tuned Audi engine. Both of us were using a quart in 400 miles and went to less than a quart in 5000 miles, or in my case no oil consumption at all. The fella thats in Texas thats tuned uses less than a quart in 5000 and 6000 mile intervals. He's been using Speediognistics for analysis on every singe oil change, and Lake said 6000 miles is fine and the interval he'd continue with on this tuned supercharged 3.0 CREC engine moving forward. The VR&P is showing extremely low wear numbers on his engine with now over 200,000 miles on it. Its amazing to see the results with unsticking the rings on all these engines using VR&P along with Berryman B12 piston soaks and/or Yamalube Ring Free plus to do a quick unstick of the oil control rings have done.
Many fellas are running VR&P in there high HP twin turbo 4.0 V8 putting out over 600 HP and it's fixed their consumption woes. Keep in mind Audis spec is to use 40 weight Euro oils, and these recommended oils is what got them/us into the consumption problems in the first place sticking & coking the oil control rings on these German made vehicles.
It’s funny to come here and see people that are still skeptical or refuse to think outside the box and worry about manufactures approved oil specifications. It's part of the reason I don't visit here much anymore because of the all the Johnny Skeptical's and naysayers who worry about putting it in their vehicles. Just stick to using a 5 or 6000 mile interval and use it forever to clean it up and keep it clean. The UOA's are showing better wear than the 40 weight Euro oils these guys were using previously for those that have done the sampling. Imagine using it in twin turbo V8 600 plus HP car that runs very hot under the hood in that 4.0 liter hot V and shows better wear protection AND cleans up the rings and engine internals! Talk about a win-win!”
