Black smoke
Tape
Hell
2021 Redeye
You're backwards. Air / (over) Fuel. 13.5 is lean (for WOT). Cruising under no load, most modern vehicles will go higher than 15 AFR for mileage.
Just realize what you're saying, yeah you're right, I'm backwards. Do you think running this car around 15 would be to lean?
These cars shouldn't have that much black soot, or should they?
Check your plugs. If they are black, you need an adjustment. You are losing power
Hemiride
Hemiride
Farwell
Thread Starter #23
When mine was stock it would show 14 AFR cruising. 15 seems lean to me.
Tape
Hell
2021 Redeye
Mine shows 13.7 most of the time cruising and a lot of black soot in the tail pipe, after driving it a few days and not going WOT then hitting it I get a cloud of black soot which is all the soot that has built up. I'm just wondering if this is the norm running a supercharged motor but it just seems too rich to me. If I get a Diablo tuner will I be able to adjust that out?
Never mind about Diablo tuner, I found out you have to spend about $1500 and replace the PCM.
Hemiride
Hemiride
Farwell
Got the car out today
Humid and about 80 degrees.
Afr at wot was 10ish. I even saw 9.9. I asked for a safe tune but that seems too rich to me
That is VERY rich for gasoline. That’s what I’m seeing on my flex tune with E70
Hemiride
Hemiride
Farwell
Thread Starter #27
My son talked to the tuner.
He said
The "cat protection was kicking in" the computer adds fuel to cool the exhaust because the cats were getting too hot.
I didn't know that was a thing
Hemiride
Hemiride
Farwell
Thread Starter #28
He also said 16lbs of boost is a lot for 93 octane. Which I agree with. I was only expecting 13lbs with a 2.85
