- Member ID
- #1122
- Messages
- 29,878
- Reactions
- 63,680
- Likes
- 352
- City
- Orchard Park
- State
- NY
- Country
- United States
- Vehicle
- 2018 Demon 2016 Hellcat 2023 170 Demon 2006 Viper
The tire composition actually gets less elastic and more like plastic in cold temps. Generally, it is not recommended to drive them in temps 45 or less. Here’s something I found on the internet
Be warned: because the rubber compound on the drag radials is very sensitive to temperature changes, it's a double-edged sword. You'll enjoy better straight line traction when the air temps are above 60 degrees (F.). But if you decide to drive your car on a cold morning or a cold night, and the air temps are below 50 degrees, you'll find that the drag radials have worse traction than standard radial tires do. If you drive in 40 or 45 degree weather, even with the pavement dry, you step on the gas going into a turn, and find that they spin as though it was raining out.
3
- Show All
