Got a new toy and I like it!
Scared me,,, thought you said boy. Didn't now you were pregnant. Didn't look pregnant. Fine job.
I guess my red neck is just to rough with it or the fact that I leave it in the odb2 for long periods of time ,I've got it in the double bypass in the truck now maybe it will last longer being I don't have to remove it so much ,,also if your logging and it sticks pull off the burn box ,when it was hooked up on mine it caused it freeze up during logs and I have a pretty full list of pids ,since I removed it works fine
You may be on to something.....I've had my burn box connected to a double bypass in the trunk. :unsure:
hellno
memphis
Now I’ll just use the burnbox at the track for cool down and burn out then just unplug it and start the data-logging
I check for any updates and if there’s a reset for it I don’t know how to do it , I ran two usb cables from the trunk to the passenger seat so I just plug in the lap top and no cables running to the OBD underneath the dash
