need help !! COOLANT PUMP ISSUES
hellno
memphis
hey guys i have a franfenstein car here ,,18 scat pak that someone converted to a hellcat but the coolant pump for the supercharger doesnt work,has line buss faults (MY TEST SHOWS IT TO BE A BAD PUMP ) CUSTOMER CLAIMS ITS A NE MOPAR PUMP ,I WAS WONDERING IF THERES AN AFTERMARKET PUMP I COULD REPALCE IT WITH AND PUT IT ON A SWITCH TO MAKE IT WORK ,,OR IF THERES A AY TO MAKE THIS OEM PUMP WORK OFF A SWITCH ???
You would have had less problems converting from Catholicism to Judaism......( dont say it..I know I'm a Jerk:giggle::giggle:;))
hellno
hellno
memphis
BROTER I WOULD HAVE NEVER DID THIS KINDA OF SWAP MYSEL ,IM JUST TRYING TO HELP THE GUY OUT ,,BUT ONE WAY OR ANOTHER ILLL FIGURE IT OUT
I get it...I'm no help..I just get in ...and drive...(but just couldn't resist bein a jerk)
Who is this person
Is the car unlocked and tuned?
Is the pump bad or not? How was the swap done? Is the PCM and everything unlocked?
If the pump tests good it's a wiring/BCM config issue which can be corrected. If it's bad, you'll have to disable DTCs for it if you want to run an aftermarket one off a switch. CWA400 pump is aftermarket and will work when you power on the car
(If you want no codes)
That's the expensive route. A Davies Craig pump (looks like a turbo) is cheap and will work just as good and actually better than the stock pump
Same one you'll see connected on the outside of ice tanks. Like $150
