Want to charge an EV? How much will it cost?
Great. Another 700lbs of fuel would be grand to cart around on a road course.
AND, Not stopping for 4-6 hours? BULLSHIT, unless you are monitoring your fluid intake & release scientifically, can empty that bladder 100% every time and have a on/off switch on those kidneys. Some of us know a lot about that.
Luckily the fuel I use is nowhere near that heavy. Besides, there's no law against not filling the tank to capacity.
Before leaving and while on a trip I don't eat or drink anything, so driving for 12 to 14 hours without stopping is no big deal. It's having to stop for fuel before I need to stop that sucks.
That's why I like vehicles with large capacity fuel tanks...and could never have an EV.
#62
50? The expected (per the marketing people, so take with a grain of salt) is 10 years. We've all heard of EVs that have already needed battery slab replacement so 50 years? No way. Not to mention, is your charger inside your attached garage? The manufacturers are telling you not to park an EV in an enclosed garage, so now it's outside and you know what effect cold has on batteries. And if it's outside, is your charging station on a post in your driveway? Or do you have an extension cord running out to it.
Exactly my point, 10 years would be a good life out of one. I just look at how fast the batteries on all my 20V tools start to deteriorate and know that there are plenty of ICE powered lawnmowers and other equipment as well as cars that lasts many decades with normal care. Hell, a lot of cars are over 75 years old and many into the 100s
#63
About finding a station with e85.
Ohhhh...well I guess it's gotta be hard seein anything with that melon on yer head....(ok ok...I promise no more melon head jokes):giggle::giggle::giggle::giggle:;)
@ my age...I make it a point to stay hydrated...(something I failed to do in my earlier years)..and I piss before dinner...(never during)
Me too !!!
[cheers]
BigSwede
Columbia
Scat Pack Shaker
#65
-It's the 170kwh ...range when fully charged,,, 400 miles....11 kwh...those are the facts,,,now move on:rolleyes:
So you’re changing the bar now. You initially said 440 miles and now you’ve dropped down to 400 and you’re saying “facts” at the end of each post. Your facts are changing to support your initial incorrect statement. I’ll leave it here but it’s not even debatable that you’re wrong even by using your own new figures.
Silverado EV...440 mile range...17 bucks and change...
So let’s go with the unlikely charge rate you claim at 11 kWh and the new 400 miles range. That is $36 or slightly over double what you initially claimed.
The Silverado EV with a 170 kWh battery has an EPA-estimated range of up to 408 miles max in its base work truck form, but this can drop to 390 miles if equipped with the options.
Real-world tests show an even lower range, with one test projecting about 340 miles in cold weather conditions, and another testing a similar truck achieving 310 miles on the highway.
I'd love to perform a controlled test of one in my environment.
Let's say its an ideal (for the car) 70 degrees. I don't use A/C and certainly wouldn't need the heater so that's not a factor. All we have here is 2-lane highways so that puts it at 310 miles, supposedly. Let's also say that I would keep it under 70 mph, and not pass anybody, unrealistic as it may be.
Now, to be nice to the car, I'll go south from here since it involves the least change in elevation, only about 2,500 feet in about 100 miles, and since it's downhill it'll be happy. But then I want to get back home again.
That should leave me with some 210 miles to go, which isn't an issue in a best case scenario on paper, but if we take cumulative elevation changes into account it would be. And since there are no charging stations along the way...
Having tested vehicles for a living (no EVs, thank God) I have a fair idea of how the manufacturer's claims compare to real life usage.
BigSwede
Columbia
Scat Pack Shaker
#67
I remember reading an article years ago about how the EPA tests the cars and the cars are put on a dyno and you watch a screen and you have to keep a red ball in between the two lines on the screen. Too much throttle and you go above the top line. Not enough and you go below the bottom line and if either happens the test needs to be rerun.
The journalists that tried it couldn’t even keep the ball between the two lines because it required that gentle of pedal control. That told me that the numbers are pretty unrealistic to maintain.
What people don’t realize is the EPA tests less than 15% of all cars and relies on the manufacturers numbers. They just make the penalties really severe so the manufacturers won’t lie. Certainly a few have been caught though.
Yep. And why take such obscure factors such as wind resistance into account?
Makes believing in what our Lie-O-Meters claim for mpg seem quite reasonable in comparison.
#69
440 408 400.who cares...what's the difference..now yer splittin hairs...an unlikely alleged charge rate you say...I'm really not concerned with any of this nonsense....his new EV Silverado costs less than half what his Ice ram did for a 400 mile range.now if you wanna waste yer time reducing everything to fractions...have at it..end of discussion :rolleyes:
#70
On scale of 1 to 500 things I'm concerned with on a daily basis none of this shit is on the list...guys like Big Sweede really need a hobby,,:rolleyes::rolleyes::rolleyes::rolleyes:
#71
BigSwede
Columbia
Scat Pack Shaker
#72
I thought you were done? I see you don’t like being called out on lies. Actually I don’t think you were lying just uninformed and got caught so you didn't like it. I wouldn’t have persisted what so ever but every reply to me said “facts” at the end like you were right and I proved with actual facts that you weren’t.
#73
Look...nobody's lyin about anything here...and nobody got "caught" with anything...and guys like you can't help but persist.....and to be clear the ONLY thing I don't like is your inability to let this go.so ya think yer right ...Fine.:rolleyes:..Now in the name of All things Holy..knock it off and let this go...you have become rather annoying
cole3986
TBD
#74
I surprised you lasted as long as you did. I have owned three (3) EVs and currently own two (2). Love them, save us a ton of money after 100,000 miles of driving (cumulative between all three vehicles). They are stupid cheap to operate, no maintenance and charge at home. I have heard all the arguments against EVs, for running around and all trips up to 150 miles from home, they are driven.
#75
As a work truck DD (that will not be driven long distance) it makes perfect economic sense....and although I'm no Chevy guy...it's stylish..great ride..and vey quick..it was a good decision...
cole3986
TBD
#76
I know it does, EVs have a very low center of gravity and around 50/50 weight distribution (AWD/4WD versions). The only thing I have done to the EVs is replaced the 12 Volt battery and changed the tires after 45,000 miles. Brakes last forever using the regenerative braking and they are direct drive (no transmission). I am not planning on driving an ICE vehicle (daily) again.
The car registrations are going up next year from $ 75.00 to $ 300.00. I have not paid the gasoline road tax for almost 4 years and the extra $ 225.00 annual fee is nothing compared to the annual savings in gas and maintenance. There was no sales tax to buy an EV now is 3% or half of the normal tax. I haven't been to gas station in months, and don't miss it.
#77
I know it does, EVs have a very low center of gravity and around 50/50 weight distribution (AWD/4WD versions). They only thing I have done to the EVs is replaced the 12 Volt battery and changed the tires after 45,000 miles. Brakes last forever using the regenerative braking and they are direct drive (no transmission). I am not planning on driving an ICE vehicle (daily) again.
Not to mention the "crazy" dealer incentives and tax credits he got...on top of that it was a no money down..24 month lease...they practically gave him the truck
Meanwhile, I passed on a $35/mo VW lease.
cole3986
TBD
#79
Yep, that is why I am looking into a Ioniq9, if I can get a crackhead deal I will trade one of the EVs for it. I used to drive my dually on long road trips, but Costco rental car program is so cheap, that it makes no sense to drive my own vehicles when I can rent a car with unlimited miles for around $ 200 for a week. Now, the truck is used just to pull the trailers and go drag racing. My 2021 Dually has less than 19,000 miles on it (it sits a lot).
For those saying they will not last or start in 10 or 20 years from now, I don't care, my EV's have a 10/100,000 mile battery warranty and I will trade them in before the warranty expires.
why2kmax
12 Second Best E/T
Shrewsbury
#80
Is that what the dash says or the miles he actually has driven on that charge?
