Really not bad at all to do IMG_3209.jpeg . I thank @Hunter for letting me know they don’t vibrate much
Bowlerguy92
Anyone ever get P0420? I’ve got hi flow cats in my build and hadn’t ever seen this code ironically until right after I had my car inspected 6 weeks ago. I cleared the code, didn’t come back.
Yesterday went racing and the car ran great. On the way home, the code came back again.
Is this expected with hi flows in the heat? It was hot out and obviously racing puts a whooping on the cats. Maybe something that can be tuned out if they’re falling beyond the expected threshold? Car is otherwise running like a scalded cat and putting down 9’s easy.
Really not bad at all to do View attachment 169248 . I thank @Hunter for letting me know they don’t vibrate much
Think you might have me confused with someone else.
What doesn't vibrate much?
Would love to take credit for it, but that's not me
I thought you got the BMR mounts installed? Sorry, maybe that was @Diboblo
Why are you beating cats? What did they do to you?
Site is lightening quick right now. Wow
Diboblo
Riverside
2015 Dodge Charger Hellcat!
Yeah... me.
Like them a lot. Not noisy. No vibration.
Just a little sc harmonic, but would do it again.
Sent from my SM-S918U1 using Tapatalk
Yeah... me.
My car is so loud I doubt I’ll even notice lol. Taking my sweet time torquing everything down, aka as tight as I can for most of the bolts lol. Just have to tighten starter power wire nut, throw on starter heat shield, driver side mount heat shield, and bolt for steering linkage
Hottest day of the year, maybe the decade. Lexol'ed the interiors.
Finally cut my coupler I got for my 108mm throttle body to JLT intake and put on black clamps. Got rid of the double clamp and cut up jlt coupler I’ve been rolling around on. Got some 6an hose separators coming in tomorrow that’ll fit the 8an ptfe fuel lines for my flex fuel sensor better. Here’s better pics of the setup I made and how I routed the fuel lines/connections. Hoses will look neater tomorrow after new hose separators come in.
FYI, I notice the vibration lol
Two 90 degree hose ends - 1 has a fore female 1/2” efi fitting connected to the end of the 90 degree hose end (connected to fuel rail) and the other has a 1/2” fore male efi fitting connected to the 90 degree hose end (plugging into the plastic fuel line jumper that used to go to the fuel rail). Fuel feeds to the sensor first, and then loops around via the 180 degree hose end and goes into the fuel rails. It uses a Motion Raceworks flex fuel sensor fuel bypass so that there’s no restriction in the fuel system. Fuel flows through the sensor, and around it at the same time. Hoses are 8an PTFE, with steel bearing around the PTFE liner, and nylon braiding over that. I custom made the wire harness myself, which tucks neatly into the front fuse box while it’s closed. No gauge if wires in the cabin - it uses a Bluetooth transmitter that plugs into the sensor, and is readable via an app live along with the fuel temp. I made the bracket out of 1/8th” aluminum. I need to touch up the paint on it a bit. Some low profile hex screws and nuts from McMaster, longer ARP bolts to secure it to the supercharger and the lid, ARP washers fit perfectly in the circles in the supercharger lid, so the bracket makes no actual contact with it
I _THINK_ that means the refrigerant charge is low...
Well, found out that the AC relay was shot when I took car in for service. They didn't have one in stock, but the tech pulled my horn relay and used it.
I don't mind not being able to honk the horn for a little while.
What I do mind is not having AC in South Mississippi in the summer.
Relief at last!!
Relief at last!!
STAY COOL....(after all..only frustrated women use horns)
She is out an hour to the north of home this afternoon.
Relief at last!!
Relays are an easy fix and they do go out. I have extras in my car after losing one in my fuel system last year and thought it was a pump
Took the 170 to a small local cars n coffee this morning....maybe 175 cars...WTF..there was a red 170 there already....WTF...old guy..not very sociable..:rolleyes:...(him not me)
Still waiting for my fuel line to come in. Thankfully ordered before the surprise tariffs
Suuuuure
