Winter Project: Fun with Numbers – Airflow - Free HP???
20HCM6 22RENBS2
Looking for way to make the cars faster without significant mods. One idea I had was to open up the right hood scoop. As most of you know, the right scoop on the 2019+ is mostly or fully blocked off, mine is completely blocked by what appears to be urethane foam. The reason it is blocked is a mystery but some have theories.
I ran some very elementary calculations and hope you guys might be my peer review.
THE ENGINE
The 6.2L at 6000 is demanding 657cfm. At sea level and with 14.5psi boost, the engine is looking for 1305cfm of atmospheric air.
HOOD SCOOP
I estimated the area of a single scoop to be 10.64sqin. At 200, this area captures 260cfm ignoring any losses or gains, assuming my calculations are correct.
HEADLIGHT SCOOP
Based on the approx. 5.5” ID of the bezel, that area will capture 635cfm (same assumptions).
TOTALS
Based on the above, 1 scoop plus the headlight capture 895cfm for an engine looking for 1305, so the engine is still working to get air.
BUT…. If we add in the 2nd scoop, the total captured air is 1155cfm, getting very close to the 1305 demand.
I have to wonder if the headlight plus 2 scoop was designed to meet the air demands of the car….
CONCLUSION
Based on this, I am seriously considering opening up the right scoop before Land Speed Trials next year.
As always, I welcome comments, constructive comments are even more welcome! 😉
Decay
Astoria
OR
2019 widebody Redeye
How would you direct it to the intake?
20HCM6 22RENBS2
They appear to be connected, but blocked. Take a look.
20HCM6 22RENBS2
Initial calculations considered the opening of the scoop near the rear. The scoop bezel is tapered and if I consider the full area of the leading edge, the cfm of each increases from 260 to 385. Based on that, 2 scoops and the headlight capture 1405cfm for an engine demanding 1305.
Unless I find a good reason not to, I have to give this a try next summer.
Just trying to save you some trouble.
Where is the flow from the most substantial air input to the system? The open area in the air box supported by the lower opening?
Comes in here…
Flows into and up the area under the filter…
I have also seen a description that if you attempt to open the right side of the hood the airflow will become turbulent and not work well within the SMALL air scoop hood system.
@DGatzby you beat me to that reply!
20HCM6 22RENBS2
Comes in here…
I have heard about the turbulence also, we "hear" a lot of things. If anyone comes across documentation please post it, thanks.
Underhood air is warmer, and yes, according to the numbers, a lot of air is sucked in from under the air box.
But, as we all know, cool air is king. I figure forcing in more cool air will lessen how much warm air is sucked in.
What got me on to this is it surprises me how strong the car pulls right up to the speed limiter. My guess is that at extreme speeds the car is really enjoying the high quantites of fresh air. I was thinking about what might happen if I could improve on it.
It sure appears that the opening(s) from under with the primary feed of air not only thru the 20 square inch duct opening pictured above but also is open for flow from the larger center area, probably is where lots of air enters the intake box. These other holes are minuscule by comparison. Moving good on the highway for a while, look at your intake temps. Mine are not that bad. Yours?
Keep in mind the right side 20 sq-in hole alone is enough to cool the oil cooler in this design.
Interesting thought as I remember for the OG Hellcat, the SRT engineers say it was the headlight duct and extra airflow that allowed them to call it 707hp instead of 700, and they said the '18 Demon's massive air duct helped with it's 808 hp rating, and they said the smaller left snorkel air hole on the redeye on was the reason they had to dial the rating back down to 797 hp. I always thought that was a bunch of crap, especially then when they came out with the super stock and redeye jailbreaks(same dual snorkel hood) and rated them at 807 saying they re-calibrated the tune - but really it's the extra 100 rpm that the hp is rated at that probably make the 10hp difference. Is the air filter or the access to air really the limiting factor in hp development? I'd be surprised if it is, I mean take off the filter then and let it breathe all it wants! @2ndAmend you may be on to something, who knows? Will be interesting to follow what you do.
20HCM6 22RENBS2
:ROFLMAO: I have thought about pulling the filter but the runway can get dusty.
I don't know how they rate hp, but air intakes work very differently on a dyno than they do at high speed.
The way I figure, the more O2 you can get in, the more fuel it will provide, within the limits of the tune.
Watch how this stock REWBJB just keeps pulling, add 9mph for the S2. Hell, what do I have to lose trying this?
20HCM6 22RENBS2
Ever since Bull first pointed out the hood lifting at speed I have been looking to reduce underhood pressure. That pressure not only lifts the hood, it also forces more warm air in through the bottom drain hole in the airbox. This summer I removed the master cylinder access cover and the cowl weatherstrip hoping to relieve underhood pressure. It seems to help, and the car sure seems to run better at speed. I had 6 runs over 200 this summer, set 14 records. (Had a good year, maybe I should retire??? :ROFLMAO:)
I like the intake idea because it is zero cost and virtually no risk. But I’m always open to new ideas!
The engine was rated on a dyno in accordance with SAE Standards. You can look around to determine how or what is used for intake air.
What you may lose is nothing. Even if you negate the small amount of air in the hood, it has plenty from below. I agree with Eric, other items may be more beneficial. Realize you may be a at a point the drag racers and others reach, fairly easy to get to this point, further improvements are expensive and small. Here is your enginedyno. Your welcome.
Want more? Eric is all over it, the power btw the models are in the RPM’s. My tune allows 6500😉 and 6000-6500 is where it gets serious (if I want it).
Courtesy of Ray. Thanks buddy!
20HCM6 22RENBS2
Thread Starter #13
View attachment 172867 View attachment 172868
Are you saying that adding more free fresh air is a waste of time?
IDK😁
You think the engineers left a simple amount of power on the table with the air box design?
CPO Super stock
westminster
2021 Superstock
most likely maybe.
Or maybe the hood lifts partially because of all the air being forced into the engine compartment through the lower intake?
Need vents to get that air out from under the hood
There is a “release” vent in the lower part of the front wheel lining (both sides). That could and does allow excess air flow out and back in front of the front wheel/tire.
Okay, really wanting to help and not get you in trouble at those speeds. Oh and, yours truly could appear at one of these.:love: So I have a real purpose here, besides just discussing this really good subject. ;) I am negotiating to have a couple of items changed/replaced on my car, TODAY, that are necessary b4 any more fun days, otherwise I was seriously considering going to AR next week.
I do not like GPTChat because that free one is a POS. But CoPilot who I have and pay for, has bullshitted with me before and has my respect as one of the best gear heads that I have ever discussed cars with!! That says a lot. Have some time this morning in the middle of a shit news and market day. It substantiated everything we said above. See some of the good facts it showed me a bit ago.
So…Be careful…
“At 200+ mph, you’re not just dealing with intake efficiency, but managing pressure zones, heat dissipation, and aerodynamic stability.”
Option 1: Do Nothing — and Be Proud of It
• Why it’s valid: Dodge’s tri-source intake, wheel liner venting, and hood scoop design are already optimized for high-speed airflow and pressure relief.
• What to tell him: “You’re not leaving performance on the table — you’re preserving the factory-engineered balance. At 200+ mph, that matters more than tinkering.”
Option 2: Subtle Enhancements That Don’t Disrupt OEM Flow
If he insists on doing something, here are low-impact ideas that won’t compromise the Redeye’s design:
• Replace wheel liner screens with higher-flow mesh - from me—IDK how much better flow can be gained here, the mesh is already about 1/2”x1/2”.
Improves pressure relief without altering the vent geometry. Just ensure it doesn’t allow debris into sensitive areas. From me- I have some leaf debris and have seen other shit because of the HOURS of high speed runs on road courses on mine. I even nailed a bird at 140 one day into the lower area. It died, damn had to scrape it off the mesh in front.
• Seal non-functional hood scoop - from me—oh!! What he does not know is that is nearly sealed already. (I have performed a couple of smoke tests myself long ago)
If one scoop is cosmetic, sealing it can reduce turbulence and prevent hot air re-entry at speed. From me - I know I have seen somewhere in the past five years that opening it will cause turbulence.
• Add temperature/pressure sensors
Install under-hood sensors to monitor real-time pressure and heat. This gives data to validate whether ANY changes are actually helping.
There you go. Hope to do one myself so we can compare the “warranty” tune you have to a benign no different pulley aftermarket tune, similar to the Demon type high octane tune that they came with in ‘18 that I run. I will add more octane fuel than I do on a road course due to the limited run distance and have Jon “turn it up”.😍😍😍
I have a little suspension adjustment that needs done along with a darn rear axle that requires some attention before this thing does anything but limited street time.
20HCM6 22RENBS2
Thread Starter #20
So…Be careful…
And fairly easy.
