Power stop brake squeal
#41
One of my front DTC-70’s
One day BIR
Flip - little day at local track
Then; One day RA
I never find any paint on my pad backing plates, only flakes and some larger areas that just peel away.
These wore real well, they have some life remaining. Like TD these will go into a box of used. I did put a set of one day at BIR fronts for this past Sunday at RA also. That was such a short and wet day, they will survive for one more day somewhere.
Smitty
Canton
2019 Challenger HC WB
#42
Ok, who wants to see a dyno run video???
(For those that haven't already seen it.)
Me! Me! Me![lockdance]
This is out of context, so don't try to put too much into what it is or isn't. The one point I will say is that it is not a CDT rotor, but it is a test that we developed.
Smitty
Canton
#44
Holy crap! The sparks are a flyin’
Finface
Morning View
KY
#45
Fascinating video of the test, Bull. So that replicated a lap at BIR (more or less - understand not to read too much into it).
I saw another test of brake pads on YouTube a while back, but it didn't look as hellish as this one!
One of my potential takeaways (chime in, anyone) from watching this is if I want to come off track early before the "cool down" lap is...to consider driving my own cool down lap. Call it an easy lap with minimal braking, while trying not to get in the way of other drivers, so my car doesn't catch on fire *grin*. Dang!
Do people come off track with red hot rotors?? Those look like they'd melt the tire, or maybe the asphalt under the car.
Thanks for sharing...I think!
The test circumstances that caused this to happen are a unlikely, but possible scenario.
Firstly, don't use a "street" pad to race at this level! The CoF for this pad in this scenario was nothing short of horrendous, ~.15-.20. (The reasons for why this particular test was done with a street pad and not a track pad are "complicated". :unsure: )
Also, I'm still waiting for the final report/data from this test. Frankly, I'm not entirely confident that the test lab set up the parameters correctly or as specified. The good news is that if that ends up being the case, changing/correcting them is relatively easy.
Also, the dyno instrumentation is really good about outputting the actual conditions that it applied, regardless of what you intended or programmed. For example, and this is critical, the actual energy in, and the duration of each specific event is documented. One example of this is if you program 150mph but the dyno motor either under or over speeds the inertia disks, the actual speed (energy) is recorded each time. (FYI, it gets very close, usually within a couple of tenths mph.)
Finface
Morning View
KY
#47
One day BIR
Then; One day RA
We shall call you "Hawk, The Destroyer".
Of brake pad paint!
Prange
no longer in Chicago
2021 Charger Scat Pack
#48
Bull,
Thanks for the video.
Finface
Morning View
KY
#49
"Firstly, don't use a "street" pad to race at this level! The CoF for this pad in this scenario was nothing short of horrendous."
I have stated my appreciation for the shared expertise on this forum before, but you stressing this caution is a service to people who haven't gotten the word about brake pads. Fortunately for me before I went to the road course I learned of this forum, and this subcategory about tracking our heavy cars. I was warned never to go to a road course with street brake pads. Lucky me.
Any person new to the sport of road course tracking, perhaps even the drag race scene, is going to see marketing/branding of brake pads with "Extreme", "Performance", even "Street/Track" labels. To the uninitiated they would have little idea that these mostly ceramic-based pads are unsuitable, even dangerous, for 20-30 minutes of near constant hard braking.
Man you guys are hard on brakes. Slow down and they will last longer:)
#51
I keep telling @TrackDay that, and he keeps telling me to press it harder for better times. Darn it, he IS right, is the problem.
TrackDay
Great White North
2016 Dodge Challenger
#52
I've pulled off at Brainerd and Road America before and seen smoke coming from my front wheels. It's always been when I come off without a chance to do a cool down lap. That reminds me to go through the parking lot or access roads at 20 mph or greater if possible and stay off the brakes for a few minutes.
