Thread Starter #1,301
D9C80394-11A6-4154-BDD6-18A27534C2FE.jpeg 3771C141-76F0-44A4-BF4C-4C8DCE2DE2C2.jpeg CECCF91E-6815-4BFC-8ABC-7B5AA6FDB57C.jpeg
Front and rear broke. She was sent. I have a copy of the obituary:
Today we pay remembrance to my DSS one-piece. Born September 29th to @fumanchu182 and @HighHorseman . A resident of MIR, Cecil and Capitol, the drive shaft is survived by a 2015 Hellcat, 2016 Dodge ram and the drive shaft shop. The driveshaft was a ardent supporter of burnouts and quarter mile passes for three race seasons. Viewing services will be available till 3/13 when recycling will collect. 🫡 🇺🇸​
However super easy install. The hoop was damaged so ill be ordering another one soon. Better it than my undercarriage.
F691C1D5-205C-4D9B-9BAF-C04F50D94D62.jpeg 22ECCB47-26CF-4133-ACF5-E2EB46503FE2.jpeg
3.5 inches from edge to edge, fully in spec.
View attachment 99880 View attachment 99881 View attachment 99882
View attachment 99885 View attachment 99886
Only way it would be out of measurement would be if they made it wrong. So they want you to check their work:unsure:
This is the one Jon and I swapped out at the track for another racer last year
Junk. I’ll never own a 1 piece again unless it’s a wiles
Just put a new boot on it. Junk
Thread Starter #1,306
Checked the logs, everything is good, got out of it at 22mph/6200 rpm, engine didn't spin past that so not going to worry about the trans. Axles are still in and they will enjoy every fucking second of beatings I give them and then when they go. The bigguns are on deck..
Nice. What driveshaft are you putting back in the car?
Thread Starter #1,308
Ummmmm... Scroll up 🤣
I would put those in and keep the others as backups or sell them. Once you break them at the track it will be another inconvenience
Didn’t realize that was a new one I wouldn’t have put another DSS but that’s just me, I’ve had 2 that have gone out of balance on me, 1 is still on my shelf. Zero issues with Redeye driveshaft and I’m not sure many people have broke them. I’m going to get the replaceable carrier bearing eventually
At what speed did you notice the imbalance?
Thread Starter #1,312
I've broken one red-eye and one regular hellcat one. In fact the red-eye one is sitting in my shed. Carrier bearing went boom.
40 and above. When I say out of balance I mean literally violently shaking the entire car making a noise you can’t yell above.
The actual connection or just the rubber. They have a fix for that now. I meant broken at the cvs or twisted them
Running mid 9s and slower probably fine. Will be interesting to see what car 7 has with its 1.29 60 ft:unsure:
P
not many cutting a 1.2 60’ lol and I’d hope you have more than an aftermarket driveshaft for that. I’ll never do DSS again. Wiles only
My thought on all the imbalance of the aluminum shaft i think is installation. In the trans they fit real tight why they are a pain to get them out. If it isn't in all the way or tilted a little bit I could see the bolts still going in and causing a vibration. Saw the same thing with the late model mustang
My thought on all the imbalance of the aluminum shaft i think is installation. I the trans they fit real tight why they are a pain to get them out. If it isn't in all the way or tilted a little bit I could see the bolts still going in and causing a vibration. Saw the same thing with the late model mustang
Good to know.
P
Nope but once you make more power then what the part was intended to do you look for something stronger. All the 1 peice shafts are rated for more hp then the stock one
I have the exact same issue but only after 120. Scared the devil out of me.
