Rear Diff and Transmission oil change
Hellcatcfp
2018 Charger Hellcat - 53,427 miles.
Looking to change rear diff oil and maybe get a magnetic drain plug?
A little hesitant about changing transmission fluid due to creating issues? Most likely have my local shop help. Any advise or issues other than expensive fluid?
Coolant has been done multiple times due to warranty repairs...so good on that for a while.
Appreciate it.
Appreciate it.
@16GoManGoHC2 for plug
THANK YOU @BULL !!
If you’re looking for magnetic drain plugs I make the strongest and most say the best out there. They’re a bit expensive but they work. For Hellcat, Redeye, Demon, etc and many other brands Ford, Toyota, Nissan, etc.
A8 Set below, left to right Engine drain plug, Oil Cooler drain plug, Diff Drain, Diff Fill, A8 drain plug.
Oil Cooler and Engine
Diff Fill and Drain
A8 Drain plug
M6 TR6060 Fill and Drain
Message me if interested
Hellcatcfp
Hellcatcfp
THANK YOU @BULL !!
Diff Fill and Drain
A8 Drain plug
View attachment 178099 View attachment 178100 View attachment 178098
Fantastic. Will do. Let me decide on what I need. Thanks @BULL for reminding me about this. Thanks again everyone.
Definitely get one for the diff, I have some metal in mine.
I had both of these done somewhat recently, both at the dealership. Diff was real quick and pretty cheap, tranny was more expensive as it is sealed with a removable panel/cover that has the filter built into it that they replace when they do this. Dealer tech said the tranny did a real weird thing and clunk when they engaged it for the first time, performed a relearn procedure on it, and it has been flawless ever since. Maybe it was just pressurizing back up? I dunno, they told me to be really alert to it for a bit, but I have not had as issue. It actually performs and shifts great.
Probably didn't fill it right, there's a very specific fill procedure. You can't do the trans unless you have the car in the air and someone in the car going through the gears while you fill
You can't fill the transmission or even pull the drain plug with the car off and not running
Good info, where were you when I was getting the service done?!? ;)
Do you think I have anything to worry about. My platinum warranty expires in September, I was gonna have the car really looked over before that for any potential claims. My service advisor and tech are really great and will do what I want/need. They actually brought up the tranny but I was like nah it seems to be working great.
I'd just confirm that they followed the fill procured and ask if they checked the fluid level with the car off or running and see what they say
You need to do the fill procedure between a certain temperature range. Put the car in first, foot in brake. Reverse, foot brake. Bring up rpms, etc. it's a very specific process - it ensures everything is full of fluid when you check the level to confirm if it's actually full or not since there's no dipstick
Hellcatcfp
Hellcatcfp
I would certainly hope a dealer would have the official procedure for the transmission oil change. Definitely going to do the diff with magnetic plug. Not sure on transmission as I really don't trust it will be done right anywhere I go...don't want to do more harm than good with someone messing with it. Will call and talk to my shop I go to and see what they think...we shall see.
Diff change is piece of cake, do it yourself.
Trans fluid is a nightmare.I watched the vids and figured the tech is more likely to fk it up and make everything worse. I hope to never have to deal with it.
Where did you get the cheap diff oil?
I posted this last Tues on the other thread:
Couple days ago I logged into my mopar.com account and checked out coupons at local dealers. All have a $145 for 2 Pennzoil Syn 7q changes, sounds good to me. Some 15% off, one had a $25 off parts or service, but Jeep had $50 off parts or service.
Stopped by today and bought a L of diff fluid $62, paid $12!!! I like bargains!!!!
Sorry I missed it
Well Publix market has MELONS on sale ...1/2 price....geeze dont miss that one....:giggle::giggle::giggle:;)
Hellcatcfp
Hellcatcfp
Regarding rear diff fluid...run 75w-85 or seeing some say 75w-90? What do you all think? Appreciate it.
My thought is:
If there is ever a warranty claim, I can show the receipt for the OEM fluid. If they drain it and it comes out purple, they can possibly dispute the claim.
68083381AA (I understand there is a AB available now, but the dealers don't have it yet.)
Hellcatcfp
Hellcatcfp
My thought is:
Yes, for sure. I'm out of warranty now...probably should stick with what is working?
